Home > Sighthound Video > Using Sighthound Video > How do I add a timestamp?
Add timestamps to exported clips
1) Select the clip or clips you wish to export, and select Tools > Export clip(s), or right-click the clips and select Export Clips
2) Check the box next to Add timestamp overlay
Add timestamps for remote access
1) Go to Tools > Options > Remote Access > Advanced (on Windows) or Sighthound Video > Preferences > Remote Access > Advanced (on Mac)
2) Check the boxes next to Overlay timestamp on live view and Overlay timestamp on clips
3) Click Save and your clip, with timestamps, will appear in the set location.
