What cameras can I use?
Sighthound Video supports virtually any IP camera or webcam. A description of camera types, as well as a list of pre-configured IP cameras can be found below. If you have an IP camera that is not listed you would like added to the app or you are having trouble connecting to a camera, let us know and we'll be happy to help.
Network (IP) cameras
To use network cameras, Sighthound Video requires some model-specific settings to be entered. Sighthound Video should work with almost any IP camera, except those few that do not expose a direct video feed. Cameras that appear in the list below have their settings pre-configured in Sighthound Video. If your model is not in the list, you can try settings for similar models, consult your manual, or your manufacturer or us for help. We highly recommend using H264 streams if your cameras support this. Incoming video from cameras that are not H264 must be decoded and will significantly increase the resource usage. More details can be found here.
USB and Firewire webcams
Sighthound Video supports the standards needed to work with any camera that plugs into a USB or Firewire port (including cameras built into laptops or monitors). Incompatibilities with specific models and workarounds are described here.
Analog (CCTV) cameras
Sighthound Video does not work directly with analog cameras, but there are products called "encoders" that convert analog video signals to digital formats. Some encoders are listed below, and others may work if you can find the appropriate settings. More information on compatible encoders can be found here.
Some of our pre-configured network cameras include:
ACTi
ACM-1011, ACM-1231, ACM-1232, ACM-1311N, ACM-1311P, ACM-1431N, ACM-1431P, ACM-1432N, ACM-1432P, ACM-1511, ACM-3001, ACM-3011, ACM-3211N, ACM-3211P, ACM-3311N, ACM-3311P, ACM-3401, ACM-3411, ACM-3511, ACM-3601, ACM-3603, ACM-3701, ACM-3703, ACM-4000, ACM-4001, ACM-4200, ACM-4201, ACM-5001, ACM-5601, ACM-5611, ACM-5711N, ACM-5711P, ACM-7411, ACM-8201, ACM-8211, ACM-8511N, ACM-8511P, D32, E77, TCM-4101, TCM-4301, TCM-5311, TCM-5312
Airlink
AIC250, AIC250W, AICN500, AICN500W
AirLive
AirCam OD-600HD
Alibi
ALI-IPU3013R
Android Apps
IP Webcam, Ocular
Apexis
APM-J010-WS, APM-J011-WS, APM-J012-WS, APM-J018-WS, APM-J0111-WS, APM-J0118-WS, APM-J0233-WS-IR, APM-J601-WS-IR, APM-J602-WS-IR
Asante
Voyager I, Voyager II
Asgari
720U, EZPT, PTG2, UIR
AVTech
AVI321 PTZ, AVM542B
AvertX
Various
Axis
207, 207W, 207MW, 209FD, 209FD-R, 209MFD, 209MFD-R, 210, 210A, 211, 211A, 211M, 211W, 212 PTZ, 212 PTZ-V, 213 PTZ, 214 PTZ, 215 PTZ, 215 PTZ-E, 216FD, 216FD-V, 216MFD, 216MFD-V, 221, 223M, 225FD, 231D+, 232D+, 233D, 241Q - port 1, 241Q - port 2, 241Q - port 3, 241Q - port 4, 241QA - port 1, 241QA - port 2, 241QA - port 3, 241QA - port 4, 243Q, 247S, 2120, M1004-W, M1011, M1011-W, M1013, M1014, M1025, M1031-W, M1033-W, M1034-W, M1103, M1104, M1113, M1114, M1054, M3011, M3014, M3024-LVE, P1311, P1343, P1344, P1346, P3301, P3301-V, P3343, P3343-V, P3343-VE, P3344, P3344-V, P3344-VE, Q1755, Q1910, Q1910-E, Q6032-E, Q7401, Q7404, Q7406
Ayrstone
Various
Brickcom
WOB-100Ap, WOB-130Np
Bluestork
Bluepix IP Camera
Canon
VB-H41, VB-H610VE, VB-H610D, VB-H710F, VB-M40, VB-M600D, VB-M600VE, VB-S30D, VB-S31D, VB-S800D, VB-S900D, VB-S900D, VB-S905F
Compro
IP60, IP540, IP570
Cisco
CIVS-IPC-2421, CIVS-IPC-2500, CIVS-IPC-2500W, CIVS-IPC-2520V, CIVS-IPC-2521V, CIVS-IPC-2530V, CIVS-IPC-2531V, WV210
DB Power
IP030
Dericam
M801W
Digitus
DN-16053
D-Link
DCS-2120, DCS-3110, DCS-5220, DCS-6110, DCS-7010L, DCS-910, DCS-920, DCS-930L, DCS-932L, DCS-942L
Edimax
IC-3030PoE
Encore
ENVCWI-PTG1
EyeSpy247
PTZ, F+, EXT, UCam247
EYEsurv
ESIP-MP1.3-BT1
Forenix
D0100
Foscam
FI8620W, FI8904W, FI8905W, FI8906W, FI8908W, FI8910W, FI8916W, FI8918W, FI9801W, FI9802W, FI9818W, FI9820W, FI9821W
GeoVision
GV-BL1210
Grandstream
GXV3611_HD, GVX3615WP_HD, GXV3651_FHD
Hikvision
DS-2CD2332-I, DS-2CD2335-I, DS-2CD752MF-FB, DS-2CD793NFWD-E
HooToo
HT-IP206
Huacam
HCV701
Instar
IN-2901, IN-2904, IN-2905, IN-2907, IN-3001, IN-3005, IN-3010, IN-3011, IN-4009, IN-4010, IN-4011, IN-5907 HD, IN-6011 HD, IN-6012 HD, IN-7011 HD
Insteon
75790
IPCAM Central
IPCC-7207E, IPCC-9605E, IPCC-9610
IPS
E01312VW
IQinVision
IQ040SI, IQ041SI, IQ042SI, IQ510, IQ511, IQ540SI, IQ541SI, IQ542SI, IQ702, IQ703, IQ705, IQ711, IQ751, IQ752, IQ753, IQ755, IQ802, IQ803, IQ805, IQ811, IQ851, IQ852, IQ853, IQ855, IQD40SI, IQD41SI, IQD42SI, IQA20N, IQA20S, IQA21N, IQA21S, IQA22N, IQA22S, IQA23N, IQA23S, IQA25N, IQA25S
KARE
N5402JV, N5403JV, N7205JV
Keebox
IPC1000W
Linksys
WVC11B, WVC54GC, WVC54GCA, WVC80N
Loftek
CXS 2200, Nexus 543
Lorex
LNB2153
Logitech
Alert 750e, Alert 750i
Marmitek
IP Eye Anywhere10, IP Eye Anywhere11, IP Eye Anywhere20, IP Eye Anywhere21, IP Eye Anywhere470, IP Robocam8, IP Robocam10, IP Robocam11, IP Robocam21
MOBOTIX
T25
Neo CoolCAM
NIP-06
Nilox
16NX2601FI002
OpenEye
CM-715
Panasonic
BB-HCE481, BB-HCM311, BB-HCM331, BB-HCM371, BB-HCM381, BB-HCM403, BB-HCM511, BB-HCM515, BB-HCM527, BB-HCM531, BB-HCM547, BB-HCM580, BB-HCM581, BB-HCS301, BL-C1, BL-C10, BL-C20, BL-C30, BL-C101, BL-C111, BL-C121, BL-C131, BL-C140, BL-C160, BL-C230, KX-HCM110, KX-HCM280
Polaroid
IP302
Samsung
SNZ-5200, SmartCam HD Pro (SNH-P6410BN)
Sanyo
VCC-HD4600
Sharx
SCNC2607
Sony
SNC-CM120, SNC-CH140, SNC-CH180, SNC-CS10, SNC-CS11, SNC-CS20, SNC-CS50N, SNC-CS50P, SNC-DF40N, SNC-DF40P, SNC-DF50N, SNC-DF50P, SNC-DF70N, SNC-DF70P, SNC-DF80N, SNC-DF80P, SNC-DF85N, SNC-DF85P, SNC-DH140, SNC-DH180, SNC-DM110, SNC-DM160, SNC-DS10, SNC-DS60, SNC-P1, SNC-P5, SNC-RZ25N, SNC-RZ25P, SNC-RH124, SNC-RH164, SNC-RS44N, SNC-RS44P, SNC-RS46N, SNC-RS46P, SNC-RS84N, SNC-RS84P, SNC-RS86N, SNC-RS86P, SNC-RX530N, SNC-RX530P, SNC-RX550N, SNC-RX550P, SNC-RX570N, SNC-RX570P, SNC-RZ50N, SNC-RZ50P
Sricam
AP008
SURIP
SI-E534, SI-E536V2, SI-E537, SI-E538, SI-E553R, SI-E555R, SI-F1034, SI-F1037, SI-F1038, SI-F1053R, SI-F1055R, SI-L934, SI-L936V2, SI-L937, SI-L938, SI-L953R, SI-L955R
Tenvis
JPT3815W
Toshiba
IK-WB11A, IK-WD01A
TRENDnet
TV-IP100W-N, TV-IP110, TV-IP110W, TV-IP200W, TV-IP302PI, TV-IP312, TV-IP312W, TV-IP400W, TV-IP572P, TV-IP572PI, TV-IP572W, TV-IP572WI, TV-IP672P, TV-IP672PI, TV-IP672W, TV-IP672WI, TV-VS1P
Vivotek
CC8130, CC8370-HV, CD8371-HNTV, CD8371-HNV, FD8134, FD8166A, FD8166A-N, FD8166A-R, FD8167A, FD8169A, FD816B-HF2, FD816B-HT, FD816B-HTa, FD816BA-HF2, FD816BA-HT, FD816C-HF2, FD816C-HSF2, FD8182-F2, FD8182-T, FD8184-F2, FD8367A, FD8367A-V, FD8369A, FD8369A-V, FD8369A-V, FD836B-EHTV, FD836B-EHVF2, FD836B-HTV, FD836B-HVF2, FD836BA-HTV, FD836BA-HVF2, FD8382-ETV, FD8382-EVF2, FD8382-TV, FD8382-VF2, FD9171-HT, FD9181-HT, FD9371-EHTV, FD9371-HTV, FD9381-EHTV, FD9381-HTV, FE8182, FE9181-H, FE9381-EHV, IB8367A, IB8369A, IB836B-EHF3, IB836B-EHT, IB836B-HF3, IB836B-HRF3, IB836B-HRT, IB836B-HT, IB836BA-HF3, IB836BA-HT, IB8382-EF3, IB8382-ET, IB8382-F3, IB8382-RF3, IB8382-RT, IB8382-T, IB9371-EHT, IB9371-HRT, IB9371-HT, IB9381-EHT, IB9381-HRT, IB9381-HT, IP7131, IP7132, IP7330, IP7361, IP8166, IP8330, IP9171-HP, IP9181-H, IP9181-HP, IZ9361-EH, MD8563-EHF2, MD8563-EHF4, MD8564-EH, MD8564-EHF2, MD8564-EHF4, SD9161-H, SD9361-EH, SD9361-EHL, SD9361-EHLU, SD9362-EH, SD9362-EHL, SD9362-EHLU, SD9362-EHU, SD9363-EHL, SD9364-E, SD9364-EH, SD9364-EHL, SD9365-EHL, SD9366-E, SD9366-EH, SD9366-EHL, VC8101
Wansview
NC541W, NCB541W, NCM621W
Wirepath
WPS-750-DOM-IP
Y-Cam
Black, Knight, White
Yanmix
EasySE-IR1, EasySE-IR2, EasySE-F1, EasySE-F2, EasySE-H3
Zavio
F731E
Zonet
ZVC7610, ZVC7610W, ZVC7630, ZVC7630W
ZyXEL
IPC-3605N
