Jul 10, 2023
Menus
Windows
File menu
- Exit. Quits the application, but leaves cameras running if they are turned on.
View menu
- Monitor View. Switches to the Monitor view.
- Grid View. Switches to the Grid view
- Search View. Switches to the Search view.
- Show Boxes Around Objects. Displays boxes around moving objects in videos in the Search view.
- Show Different Color Boxes. If Show Boxes Around Objects is selected, then yellow boxes are displayed for people and green boxes for other moving objects.
- Show Region Zones. If viewing a video clip that was recorded because it triggered a region-based rule, a red box is displayed around the region in videos in the Search view.
- Show Daily Timeline. Displays the daily timeline in the search view.
Controls menu
- Play/Pause. Plays the selected video if in Pause mode, and vice versa.
- Previous Clip. Selects the clip before the one being currently viewed.
- Next Clip. Selects the clips after the one being currently viewed.
- Top Clip in List. Selects the first clip in the list on the page.
- Bottom Clip in List. Selects the last clip in the list on the page.
- Previous Day. Changes the list of clips to the day before the one being currently viewed.
- Next Day. Changes the list of clips to the day before the one being currently viewed.
- Next Frame. Advances to the next frame of the currently viewed video.
- Previous Frame. Moves back to the previous frame of the currently viewed video.
- Forward 2 Seconds. Advances two seconds in the currently viewed video.
- Backward 2 Seconds. Moves back two seconds in the currently viewed video.
- Next Event in Clip. Skips to the next triggered event in the currently viewed video (blue mark in the playback bar), or the end of the clip.
- Previous Event in Clip. Skips to the previous triggered event in the currently viewed video (blue mark in the playback bar), or the beginning of the clip.
- First Event in Clip. Skips to the first triggered event in the currently viewed video (blue mark in the playback bar).
- Continuous Playback. Auto-progress through a given search. See this article for more details.
- Half Speed. Clips will be played at half speed.
- Normal Speed. Clips will play at normal speed.
- Double Speed. Clips will play at double speed.
- Triple Speed. Clips will play at triple speed.
- Mute Audio. Clips will not play audio
- Back. Selects previous cameras in the Grid view
- Forward. Selects next cameras in the Grid view
- Zoom in. Zooms in to selected camera(s).
- Zoom out. Zooms out of selected camera(s).
Tools menu
- Export Clip... If you select a video clip or clips in the search list of the Search view, this lets you save a copy of the clip(s) as an .mp4 file.
- Delete Clip... If you select a video clip or clips in the search list of the Search view, this removes the clip(s) from your list.
- Select All Clips. Selects all of the video clips displayed in the search view list.
- Add Camera... In the Monitor view, this displays a wizard to set up another camera to work with Sighthound Video. Note that you have to configure and set up the camera before connecting it to Sighthound Video. Details of this wizard can be found by selecting your configuration in the Getting started tab.
- Edit Camera...In the Monitor view, this displays the setup wizard and allows you to change settings of a camera that is already set up with Sighthound Video.
- Edit Camera Locations... In the Monitor view, this allows you to change the name of a camera.
- Remove Camera... In the Monitor view, this removes a camera and (optionally) the associated video clips and rules.
- Reconnect to Camera... In the Monitor view, this attempts to connect to a camera when the connection has temporarily been lost. Sighthound Video attempts to connect to cameras automatically, but this option lets you try to connect immediately.
- Arm Cameras... (Basic, Home and Pro Editions only) Displays a dialog that lets you select a set of cameras to turn on immediately or after a delay.
- Turn Off Cameras. (Basic, Home and Pro Editions only) Turns off all cameras in one step.
- FTP Status. (Basic, Home and Pro Editions only). If you have rules set up to save clips to an external FTP site, this dialog tells you if there are clips that have not yet been uploaded.
- Options. Displays a dialog that lets you configure how much disk space to allocate to video and setup remote access.
Help menu
- Reference Guide. The menu command to access the web-based documentation you are currently viewing.
- Support Forums. Opens your browser and takes you to the user support forums.
- Learn About Upgrade Features.... Opens your browser and takes you to a web page comparing the features of the different editions of Sighthound Video.
- Report a Problem. Allows you to send a bug report and your video logs to Sighthound (but NO private data or video clips are sent).
- Show License Information. Information about your licenses.
- Check for Updates.... Checks if a newer version of Sighthound Video is available.
- Release Notes. Information about past updates.
- About Sighthound Video. Opens your browser and takes you to a web page with information on past updates.
Macintosh
Sighthound Video menu
- About Sighthound Video. Information about the application version and licensing.
- Preferences. Displays a dialog that lets you configure how much disk space to allocate to video and setup remote access.
- Services. Displays OS X options.
- Hide Sighthound Video. Hides the window showing the application.
- Hide Others. Hides windows of other applications.
- Show All. Shows all windows.
- Quit Sighthound Video. Quits the application, but leaves cameras running if they are turned on.
View menu
Controls menu
Tools menu
- Arm Cameras... (Basic , Home and Pro Editions only) Displays a dialog that lets you select a set of cameras to turn on immediately or after a delay.
Window menu
- Minimize. Makes the Sighthound window small and places it in your dock.
- Zoom. Select to make the window full-screen size and back.
- Bring All to Front. A Mac OS command that doesn't do anything with Sighthound Video.
- Close. Quits the application, but leaves cameras running if they are turned on.
- Sighthound Video. A Mac OS command that doesn't do anything with Sighthound Video.
Help menu
- Release Notes. Opens your browser and takes you to a web page with information on past updates.
