Jul 13, 2020
Continuous Playback
Continuous Playback will auto-progress through a given search, allowing you to sit back and watch through the day's events without interaction. When the end of a clip is reached the next clip in the search results list will automatically begin. This feature can be found in the Controls menu, or you may simply press "C".
Notes:
- All of the navigation shortcuts work while viewing clips in the Continuous Playback mode.
- To quickly scan through a full days events try pairing continuous playback with the the "3x" speed selector.
