Home > Sighthound Redactor > System Requirements
System Requirements
Sighthound Redactor - General Required Specs
  • Windows or Linux
  • CPU: Intel i7, i9, or Xeon (9th generation or newer)
  • RAM: 16GB+
  • HD: any (SSD recommended) with sufficient capacity to store your videos
  • GPU: NVIDIA GPU w/ 4GB+ RAM (not required, but recommended for improved performance)
The application has been optimized to efficiently scale in a multicore environment. For best performance, particularly when working with long videos, a 16+ core system and a gig of memory per core is recommended.
We might recommend certain upgrades if there are concurrent users or for certain workflow considerations. Please reach out to one of our experts at
 for guidance.
